Hi, can someone please explain which timing mark on the crank pulley with the 4 slash marks should be lined up with the arrow for checking timing with a timing light when the cams and the crank are lined up to TDC when doing the timing belt? Basically I had a local shop do the timing belt recently, but they went out of business, and they put the pulley on wrong, thus I can't tell where the timing is set, and I need to correct this, and I can't find out in the IDIOTS MANUAL where things are suppose to be... Thanks in advance for any help you can offer.
Sincerely, Michael
Sincerely, Michael
