I replaced my timing belt for the second time. The first time I replaced the belt because I thought the water pump was bad. After replacing and driving for another 20K miles I still had a slow leak. So I went back in and replaced the bypass hose on the intake, that is where it appeared the small leak was coming from. Now I can not start the Pathy. The job is pretty simple especially the second time around. What did I miss? It also sounds like it is taking a lot of effort to turn over. I checked all of my plug connections and hose connections twice already. Thanks in advance.
