cruisnhard said:1.6l have one timing chain. the bigger engines have two.
Thanks for the diagram :cheers:lshadoff said:Here is a diagram of the GA16DE timing chains from the FSM:
The bottom chain drives an idler sprocket which drives the upper chain. Since the block is narrower than the spacing between the cams, the bottom chain fits in the block, and the upper chain goes to the cam sprockets in the head.
Lew
The KA24DE engine has the same timing chain setup as the GA16DE. I checked in the 1997 Altima and 1994 240SX FSMs.cruisnhard said:i thought you were asking about two chains around the cam gears like the 2.4l. i didnt mean to to give out wrong info.
