I HAVE A PROBLEM ALIGNING A TIMING BELT IN 89 NISSAN MAXIMA. THE BELT DIDN'T BREAK AND THE ENGINE RAN FINE PRIOR TO BELT REMOVAL. THE HEADS WERE REMOVED TO BE SHAVED. I HELD THE SPROCKETS SO THEY WOULDN'T TURN WHEN I REMOVED THEM. THE CRANK HAS NOT BE MOVED SINCE REMOVING THE BELT. WHEN THE HEADS WERE REMOVED THE NO. 1 & 4 PISTONS WERE AT THE TOP OF THE BLOCK. WHEN I PLACE THE SPROCKETTS BACK ON THE CAMS THE RIGHT ONE (FRONT) IS ON THE MARK ON THE BACK PLATE, BUT THE LEFT ONE (FIREWALL SIDE) IS 180 DEGREES OPPOSITE THE MARK ON THE BACK PLATE.
I CONFUSED - IF I PLACE THE BELT BACK ON AND ROTATE THE THE CRANK, WILL THESE ALIGN TO THE PROPER MARKS OR DO I I HAVE A PROBLEM. SUPPOSEDLY I CANT TURN THE CAM INDEPENTLY TO ALIGN TO MARKS. ANY ADVISE WOULD BE APPRECIATED
