41 - 60 of 82 Posts
M
Guest
Discussion Starter #43
OhTwoAltimaSE said:
San Antonio... I guess I can drive over.
yeah, and while you're at it, you can install a CAI / Mufflers / Race Pipe / Eibachs / UDP on mine :D
M
Guest
Discussion Starter #48
yes, a dyno before and after would be nice
sadly i have no idea where dyno's are in houston, or even how much they cost
i would have done a dyno to prove it
i have a base w/ muffs and CAI. If the dealer wont do it I can get the shop where the dyno is to :D 2 pulls=50 bucks
Friends of ours...
Re: dyno
3.5SE Auto said:
ohtwo, dyno again afterwards please?
i will pay half the cost for a half hour session for you (up to 50.00)
I'll pay for it to prove out if the mod works or not...
Waddy said:
OK I don't have the time to scan it and I don't have digicam with me but here is what the printout that they gave me says>
"1st printout, the stock values"
TARGET IGN TIM ADJ
SET VALUE
CORRECTED IGN TIM -1
ADJ MONITOR
CRRCTD IGN TIM -1
ENG SPEED 750rpm
CLSD THL POS ON
IGN TIMING 14BTDC
"2nd printout, the advanced values"
TARGET IGN TIM ADJ
SET VALUE
CORRECTED IGN TIM 2
ADJ MONITOR
CRRCTD IGN TIM 2
ENG SPEED 788rpm
CLSD THL POS ON
IGN TIMING 17BTDC
I'm all for the bumping up of the timing but this all i have to officially go with. So i am kinda waiting to see what others have done etc. Then I will go do it. Do you think it will need to be changed depending on the mods? say i get it done now then add UDP will that effect where the timing should really be?
Friends of ours...
Buddy02 said:
Ruben you have a base line dyno now?
Not really. I did a run at 100+ degree weather, with my CAI and stillen mufflers on.
199.7 HP, and I think 214 tq. I did some last minute changes to the CAI, and didn't get time to reset my ECU so the numbers blew.
I thinks so! thats what a stock has at wheel right? The hot weather does not help any! hows it down there now?
OhTwoAltimaSE said:
They will only adjust it to spec....
Here in California that's all they can do is adjust it to spec. it's against there smog laws to do anything else. You have to be buds with the tech.:rolleyes:
41 - 60 of 82 Posts
