1 - 20 of 34 Posts
· El Chingon
:( Yes, I can already hear the grinding on the rear passenger side. What do you all recommend for replacing the brake pads? Should I go OEM or are there better brake pads out there?
Edit: Sean, with all those miles on your car, have you had to replace the brakes?
How many miles do you have on yours?
· El Chingon
Doesn't sound right to me at all, but I can hear the grinding and the pad looks about gone..who knows, maybe it's me. But I couldn't believe I already needed brakes :confused:
That does sound strange, better take a close look. of course my opinion use factory pads. :)
Checking with service assist systom, There was a parking brake adjustment problem. Wouldn't hurt to have it checked out.
CoCo, 4 year old car, new pads and calipers. Maybe even rotors. I have a couple in my garage from when I had my trio of 94 Altys. They were turned once but still within tollerance.
They are two piece if they are the same as the 94. Rotor is about $40us new here. I can change them in my sleep. The calipers may only need new sliders or just lube.
SILENT_RUNNER said:
I would check on any hidden warantees, especially with such low mileage.
Cheers.
hidden warranties HAHAHAHHAH The do not want to honor the obvious ones;)
I won my battle with the Dealer but that is because I am Loved....
That is exactly what the Service Manager said. I`m still laughing also. I now have to go back to the origional assessment of "My Nissan Dealer is the Best".
BTW: I can`t reach U by E...........rat!
Hardcore said:
Hidden warranties? No such thing it's either warranty or it isn't. If it's a hidden warranty it's because the dealer was to stupid to know it was covered.:p
Several GM cars I owned had the brakes replaced under warantees that were not documented, but existed. I think it related to excessive wear under 10,000 miles, or something like that. Nissan may have something similiar but not advertised. It may be worth a shot. :)
Nissan did have problems with brake pad material and they know it, They've come out with several updated brake pads lately, But getting them to kick down might not be that easy. Brake pad manufactures are being forced to go with organic materials, which is softer causing premature brake pads wear. Thank our govement for that.
Doesn`t Nissan(and many others) claim that by using a softer organic material, the rotors will last considerably longer, albeit the pads have to be changed frequently. The Cost will balance Out. I have no problem with that?:cool:
1 - 20 of 34 Posts
