Still trying to gain more mpg. Are there any adjustments that can be made to the throttle body (Electro Injection)? I would like to see if a rebuild is in the future. There is a screw on the passenger side (not on the throttle linkage) of it that was wet but made no difference on where it was turned to. So I turned it all the way in and will see what it might do.
I got to playing around with the TPS today and pulled it off to check continuity through it. I only get a 0 ohm reading when it's in its home position, and when I slowly turn it to wide open throttle, it instantly reads O.L. (out of limit) which is no continuity. The only time I get a reading is when it's at the idle position, anywhere else I get nothing. I'm thinking my throttle positioning sensor is bad. Correct me if I'm wrong. Thanks.
