So this is a continuation from my last thread:
http://www.nissanforums.com/hb-truck/149835-bad-cooling-fan-clutch.html
I'm changing my thermostat since my old one does not seem to be sealing correctly when closed. The FSM says to use a liquid gasket however the original had a paper gasket and some silicone. Some resources say to use both. Which should I do?
I already have it together with just the paper one (and some silicone around the bolts) but i haven't gone too far putting everything else back together so I'd rather do it right once than have to go through this hell again should it leak.
Do i take it apart and add silicone? Do i remove the paper gasket and use only silicone? Do i leave it alone because the paper one is fine by itself?
What kind of liquid gasket is best suited for this purpose? I have Blue RTV.
