Was finally able to check compression on my 92' xe. First three holes are at 180, and the fourth is at 175. Acceptable? I am not finding any bubbles in coolant, although, oil seems awfully thin.
Straight 30w that has sat in car for a year and a half, never driven. I need to change the themostat, where the hell is it, I follow lower hose as far as I can, not far enough I guess. I cannot seam to find it? Thanks in advance
I thought the thermostat was on the engine behind the upper radiator hose?
Th thermostat is right above the belt tensioner on the passenger side. Be careful with that housing, t has a sensitive ear towards the fender. I have already snapped two of them.
freakish poster
Minimum is 164 so you're good.
