There are two temperature sensors mounted on the front side of the intake manifold. One is for the ECU and the other one, which should be the smaller one, for the temp gauge.95240sr said:does anyone know where the temperature sensor goes? i am going to get a autometer because mine is all screwed up, need to know where it goes. thanks for the help. the motor is a s13 redtop
You can install a sending unit in place of the oil pressure sensor which is right next to the oil filter.95240sr said:after looking around on the internet i found out what i will do for my water temp, but i dont know where to put a oil pressure sending unit. can anyone help me out with that
