I wanted to swap out my 98 sentra gxe ecu for the 97 ecu....I'm doing this so that I can use the techtom MDM-100 on both my nx2000 and 98 sentra.
Will I have any problems?
Does the ecu have to be special in any way aside from a MT 1.6 federal emissions?
Thanks,
Oh, Herro!
The '98-'99 cars are OBD-II, which uses a different ECU than the OBD-I models. An ECU swap is unfortunately not easily possible, and even if it could work (which is very unlikely) it would not pass emmissions. The OBD-II cars' ecus are much more complex than OBD-I to comply with the stricter federal emissions regulations that recently came into effect.
My 97 is obd II too.As long as its mt and not at it shouldnt matter but I'm not a expert{Just using common sense}I'm not to sure when they started the varible intake cam timming in the b14 mine has it though
the 1.6 from 91-99 is the same engine, except the b14s engine was tweaked a lil bit, stuff like the head, i heard the rings, and maybe a lil more.. which is why they make slightly more hp. im sure if you stay within b14 you should be cool.
I think there is a little bit of a difference between the '98 and '97. I heard that there is just a jumper you have to use or something. Basically there are only 2 wires that are different and you have to accomidate for them...I'm not 100% certain though. Do a little more research before you do. Either that, or call up Jim Wolf Tech. and ask them what to do, because I know you can do a little bit of modding to get their '97 ECU to work in a '98.
