My sunroof was not working so I replaced the motor with a used one. Now it opens but not all the way and I have to pull on it to close it.
Are there any adjustments or alignment procedures that I need to do ?
With the sunroof motor removed I have to push and pull with some effort to open and close it. Is this normal ?
I removed the entire sunroof to lube and look for any adjustments but could not find any adjustments.
I don't want to buy a new motor unless I'm sure it will fix it. New motors are $200.00.
Any help with this would be appreciated.
Dennis
All over your face!
What you could try to do is lube up the seals somewhat. What i used to do on my old honda del sol when the windows wouldn't go up all the way was lube it up with some (dielectric grease)spark plug grease (100% silicone) or use some silicone spray to lube it up. It did wonders for the seals, and the motors as well because there was less friction.
Sunroof motor
Hi Dennis,
I am also having some sunroof problems, I don't have a solution for your issue but will be watching. However, you can help me if you have your old broken motor. I could definitley use the wire connector on the old motor. Can we make a deal? Just cut the wires from the base of the motor, I'll take the 6 or so inches of wires and connector if available. Thanks
