I have a '91 Max. It is making a strange noise coming from the front drivers side. Does it only when the car is moving. Kinda sounds like a speedometer cable. Sort of a alternating wirling sound.
I know sounds are hard to explain, but has anyone ever had something like this? Not even sure if the speedo is cable or electric.
Will work for beer
check your brakes and make sure there's nothing stuck in there and that your pads are in good shape. sometimes a small grain of sand can get trapped between the caliper and rotor and it will make weird noises until it wears away or falls off.
also check to make sure you didn't hit anything and that your wheel bearings are in good shape.
Will work for beer
These cars have an electronic speed sensor, so no speedometer cable.
usually the noises are from the above causes, though there are always other issues as well...
does it only happen when accelerating or when the car is cold?
3rd gen MAximas are prone to exhaust stud breakage and they can cause some pretty freaky noises- usually sounds like ticking, but I've heard them chirp, whistle, rattle, tick, all kinds of stuff..
