1 - 14 of 14 Posts
Nissan/Mazda Gumshoe
okay i know they make everything under the sun for a b13 and up. but what about the b12, are there options out there for a brake upgrade. yes i have seen the drilled/slotted rotters for it but what about the rear? are there disc conversion options for the back. huh, anyone?:(
Moderator/ NPM staff
Front: The Se-r or NX disc brakes will work here with really no modification at all. You will notice a good improvement in stopping ability from this.
Rear: The rear is a bit more challeging. I will be covering this probably in next month's NPM. Unfortunately, there is no off the shelf answer to this.
Also a good set of braided brake lines from goodridge may do you some good.
CA18DET Wizard
I use the whole NX2000 brake set up to include it's brake booster. The rear is a bit of a challenge, but can be done if you really want them! My rear disc set up on both b12's work fine and trips alot of people when they see them.
Ex-mod/nissan guru
does someone have somekind of CAD/CAM file so i can have those rear braket done by a local shop around here ??
??...or maybe mesurments i can use to make a simple design they can use ??
help
hello i wanted to know if any1 here can tell me what do i need from the se-r or nx front brakes to swap into my 87b-12 if u can tell me step by step i would appreciate the help
CA18DET Wizard
You will need the NX2000's calipers (complete) and front brake lines. Remove your calipers and your heat shield (Very important) and install the NX200 calipers and brake lines the reverse way you removed yours.
boost_boy said:
(Complete) meant everything! The caliper is no good without its mounting bracket!
Are you talking about the spindle (upright)?
1 - 14 of 14 Posts
