1 - 8 of 8 Posts
I just bought a 91 n/a and it ran fine for about an hour but after that it started stalling when I tried to let it idle, and the RPM's wouldn't go above 2500,seemed like it was hitting a rev limiter..About an hour after I got it home I started it up again, no stalling this time but the car idles erratically, wont hold steady at any RPM, and still wont go above 2500.. what gives?
any parts prone to water leaking in? When it was running it was dry, after driving through some rain is when the problems started. I just bought the car so unfortunately I dont know much about it, anyone know whats going on?
Power FC Z32
mileage is about 114,900.
Not sure about the last tune up, its about due for an oil change and the alternator was just replaced at 114,300
have not messed with anything before the problem
I would do a major tune up since your past the tune up mark (112k miles). Every 60,000 miles a tune up is needed for a TT.
These Z32's are beautiful but the cost of ownership is pricey. You can never go cheap when doing maintaince because if you do the engine is very expensive to replace.
I think your problem is that it check needs TLC (Major tune up). Are you handy with tools? If so you can save yourself about $500.00 in labor.
Power FC Z32
1 - 8 of 8 Posts
