If you mean "brake" lines, Goodridge and Russell make sets.a96se said:any one have buying info for stainless break lines for 96 alty se
thanks
thanks for the info and spell checkbahearn said:If you mean "brake" lines, Goodridge and Russell make sets.
C'mon....... give the guy a brake....er break.bahearn said:If you mean "brake" lines, Goodridge and Russell make sets.
Rubber brake lines experience expansion to a small degree as pressure builds up. Stainless lines remove this slight reduction of force at the caliper for a slightly firmer feel. Rubber is also an insulator; the teflon/steel lines are better at transferring heat from the fluid to ambient air. This helps fade resistance.darkfms2000 said:Hello everyone, I was just thinking would it be better to change the brake lines and what it could benefit ?
