1 - 20 of 20 Posts
Anyone ever try to mate the 6 speed from the new Spec V to an SR20DET??? Im thinking that would be kewl.......any thoughts??
Thanks
Chris
AKA Manytoys
Platinum
how about JDM
I don't know if spec V transmission will bolt right up to your engine. However, there is the FWD SR20 6 speed transmissions for your car. P12 Primera 20V (Current model in Japan) comes with SR20VE with 6-speed transmisson and suppose to be a real good transmission. I hear some negative things about Spec-V tranny so if I were you, I would look for JDM tranny instead of Spec-V one.
Still moderating..sorta
Probably not worth all the hassle to get the 6-speed, but if you must, might as well get the SR20VE while you're at it.
SR20VE questions
Ok....so theres a 6 speed behind the SR20VE.....is that a turboed motor?? if not will it handle the SR20DET making about 280hp??? anyone know?? and anyone know where i could get a 6 speed from the P12 Primera 20V?? any importers out there?? im also looking for other jdm parts.......grille from lucino.....probablu others by the time i get to doing all i want to my 200sx.
Thanks
Chris
AKA Manytoys
Platinum
Re: SR20VE questions
Thanks
Chris
AKA Manytoys
SR20VE is the VVL (Valiable Valve Timing and Lift) non turbo motor... A lot like Honduh's Vtec system. 1st gen SR20VE on P11 had 190hp, but current generation SR20VE is 204hp. So that tranny should handle stock SR20DET power (205ph) just fine. There is also a engine called SR20VET (VVL+turbo) 280hp. This engine is on JDM X-trail GT (SUV) but they don't come with manual transmission.
I know someone already imported a P12 6-speed tranny over here... I guess if you got $$$, you can do pretty much anything you want.
Aint that the truth!!!!
Thats the total truth man......if you got the money you can do any gd thing you want......but for us working class ppl its a lil harder......just takes a while.......well someday ill experiment with the 6 speed/DET combo.......or maybe the sr20ve?? not sure quite yet.......hell maybe by then the prices will drop enough to do a 6 speed/det 200SX and a sr20vet sentra?? KEWL huh??
Thanks
Get the SR20VE and 6-speed tranny. Then take the turbo from the VET engine. VROOM!!!!
I don't remember where I saw it but while searching for a used 5 speed tranny to replace my idiotmatic (don't laugh, I loved the car but it was the last se-r any nissan dealership would ever have in my area.../cry) I ran across a site that sells new race trannys and had a 5 and 6 speed for 95-98 200sx se-r's...only drawback is the 6 speed was $9500 US =P
Discussion Starter · #10 ·
WISH!!!!!
I wish i had that money!!!!!.........id keep the 5 speed and just have a 9 second car!!!! but do you happen to have the site anyway??
Thanks
well im gonna try to bring this thread back to life after 5 months. my question is... is it worth the money to swap the normal sr20 tranny with a jdm one (5spd)? i found some for $500 and was wondering if it was a direct bolt in for a B14 SE-R? any mods required
Powered By hopes & dreams
87SENTRASE said:
So is this squashed? Can the SR20 bolt up to 6 speed tranny, NO. Has anybody made the adapter plate??? Has anybody solved the clutch linkage difference for those putting a 6 speed into a SR20 powered B15? Holler?
yes the SR20 can bolt up with an adapter plate. there's a 2004 1.8 Owner who swapped in an sr20det and had an adapter plate made and is using the Spec V transmission.
I personally don't think the gearing is that good for a DET.
I just want to clarify, is this JDM 6-spd we are talking about a manual? Because IIRC its an automatic and can be mated perfectly to the usdm p11, but I dont know if the p11 has to be auto or manual for the tranny to be a direct swap.
whats up guys... My buddy Jay has a shop and he is a Nissan NERD :loser: hahahaaha He is going to be putting a 6spd gearbox into a DET NX. He is very confident he can do this. Hopefully he will start this soon..
1 - 20 of 20 Posts
