I have recently aquirred a B13 SE-R. I got it. Replaced the starter, radiator hoses, added MAF, alt belt and had to install new valves because the old ones were bent. Before the car would shoot flames but not run. Had zero compression. Anyways. Now it has spark, compression and air. But the fuel is the problem. It has 42psi to the rail, but the injectors arent firing. Passenger side of the car has 2 connections I don't know where they go. Brown plug and Grey plug. Need help bad.
