150hp is what Nissan claims.
Long story. All Primera JDM SR20 motor HP is rated 150 hp. But Nissan did make changes on Primera SR20DE motors several times in past.
I say 150 is the number Nissan claims, but earlier version SR20DE probablly had more than 150hp. Back in 1990, Nissan used the first generation SR20DE engine in P10 Primera. That engine came with tubular stainless steel equal length exhaust manifold. The cam profile was pretty agressive for factory motor. (248 in 10mm /240 ex 9.2mm). Only first generation SR20DE motor came with sodium filled valves seen on DET motor. In September 92, when second generation SR20DE came out, sodium filled valves were no longer on that motor. In 1994 when P10 got the final minor change, Nissan took off the nice stainless steel manifold and changed to cast iron exhaust manifold instead.
When new P11 Primera came out back in 1995, Nissan made the another changes on that motor. If you look at the intake manifold, that's the biggest difference. Yup, that's the famours "high port->low port" thing. They lowered the Redline from 7500 > 7000 also. The new engine came with roller rocker arms with newer/weaker cam profile (240 in / 232 ex). So those are all 150HP motors, but First generation SR20DE was obviously the fastest and had most power. They all came with 10.0:1 high compression pistons with ECU with agressive fuel map and require 100 octane premium gas.
I knew this for some reason and just wanted to share this info.
