2018 Nissan Pathfinder SL
I have an SR20 and a VQ35, and when buying Oil filters noticed they are the same diameter but different heights.
SR20 listed a 6607, about 2.5 inches high
VQ35 listed a 7317, about 3.5 inches high.
Same construction according to the box, both have anti-drain back valves.
Checked the threads, both are 1.5 mm pitch, assume 20mm dia on both.
Has anybody tried using the bigger filter, will it physically fit 97 SR20.
That was my thought, if it fits use the larger one, will give it a try. usually have the Oil changed in a shop so I guess I will do the next one.
All went well, no leakage, engine noticeably quieter after the Oil change.
