1 - 7 of 7 Posts
I have this issue with my 1999 Sentra GXE. Here's the deal: the engine responds with a sputtering and messed up acceleration when I push the gas pedal too much too quickly.
Things I've noticed:
1) This doesn't really occur if the engine is cold.
2) Worse with low rpms
I've been able to drive it fine by keeping it above 2500rpm and really easing in with the accelerator. But I want to figure out the problem with this... and if anyone else has had similar issues and was able to resolve theirs.
I've tried solving it with a new fuel filter and some fuel injector cleaner, but the problem remains :(
Other notes:
cool air intake system was installed a couple years ago
I saw a similar problem HERE and one of answers looks helpful but I can't make anything from it. Any suggestions??
Did the problem start to happen after installing the cold air intake system? If so, then there may be a major vacuum leak.
Also the fuel pressure regulator may be bad.
I've noticed when I start my car the rpm's are usually low and quickly up at normal idle. Sometimes when I have stop suddenly the rpm's drop as well sometimes resulting in a slight sputtering. It has done the odd starting idle thing since I got the car, so I'm not too concerned about that, just curious why it occurs.
1 - 7 of 7 Posts
