2004 Nissan Pathfinder
286k miles
The original issue
Any suggestions?
286k miles
The original issue
- the 4wd would engage while driving causing it to jolt then stall out. There was no issue restarting it after it died.
- unplugged relays going to 4wd so it won't engage - then the car would die out as driving and had a hard time starting.
- installed new fuel filter
- changed oil
- installed new air filter
- installed new fuel pump
- replaced valve covers
- replaced gaskets
- gutted catalytic converters
- installed 2 cam shaft position sensors -installed crank shaft position sensor
- installed spark plug anti foulers connectors (drilled out 1/2")
- extended rear o2 sensors
- Starts and idles without issue
- Once engine gets hot the RPMs jump and the car starts to spit and sputter giving it more gas doesn't make a difference
Any suggestions?
