Those should be universal products, and should easily mount right on. The pedals are probably pedal covers, so they should just slip on over your stock pedals and screw on with mounting clips. The knob will either have inserts you put in with different diameters to fit your shifter, or an insert and set screws.
I've got a set of Razo pedals that sit over top of my stock pedals and have screw brakets on the back that hold them on.
Oh, if the pedals come in 2 sizes (large gas pedal, and small gas pedal) get the small pedal. And you might have to take off the gas pedal to do a little cutting to get the pedal to fit properly (it's plastic so it's easibly cuttable, and there's a clip on the back that holds it onto the gas linkage).
Hope this all helps!
