2018 Nissan Pathfinder SL
you must either fix this yourself or go and get it fixed before they fail.
If you have not done anything ie worked on the brakes, you have something failing, master cylinder, caliper etc letting Air into the system.
If you have worked on something in the brake system it might just be air, you need to bleed your brakes !!
