Hello a newbie here. I have a 94 Pathfinder I have had this for several years now, and the problem is in cold weather. When it's cold outside like 30's-40's when I crank it up and drive I get this aweful smell of gas in the cabin. Once it warms up the smell goes away. I have been unable to locate where the gas is coming from, cant find any leaks. I never have this problem thru the summer monhts, only when it gets cold. And I mean the fumes will overrun you they are so bad. I'm wondering if maybe a fuel line is expanding when it's cold causing fuel to leak, then once it gets hot it's sealing back. Maybe a loose clamp somewhere? Anybody ever had this problem? Man I need a fix before I blow up! Thanks!
