could be you caliper bolts have worked loose and the caliper is actually slamming to the front when applying the brakes. might wanna check into that ASAP
A constant velocity joint is encased by a rubber boot and is shaped like a 3 leaf clover. A universal joint is exposed and just in the shape of a plus sign. Universal joints can be serviced on the vehicle and CV joints have to be removed to be serviced.
Thanks spez. I guess the 01 Pathy LE 4WD has both?. There's something slightly rumbling under the driver's side front end. Not loud, just rumbling over bumps. No grinding that I can tell. Think it's a CV or UV joint??
sounds like a worn out upper or lower ball joint or maybe a loose or busted shock. Jack the truck up and see if you can move anything by hand or stick a large prybar under the wheel and pry against the ground and try to pick the wheel up. See if anything appears loose.
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
