1 - 7 of 7 Posts
After looking at the dyno charts I'm thinking that 6500 RPM seems to be the point for the most horsepower, for a slightly modified GA16. But does that mean that it is the best place to shift??
Your electrical friend
I always found that around 5K was where optimal shifting was for my '93 XE but I only had a CAI. The way I look at it, if the car doesn't feel like it's pulling anymore, then you're not making any more power, so it's time to shift. Now in my SE-R it's closer to 6K or more, it seems to pull all the way to redline.
Yeah i'm thinking the same as james. i can feel the lose of power right after 6500, but i wasn't too sure if i shifted there that it would put my next gear in a good place.
VVL'd
Because it is.
"The VTC likes to advance the cam at over 6600 rpm for some reason, perhaps to create a drop in power to encourage the driver to shift sooner. " - Engine Modifications by Mike Kojima
But like James said, shift as close to redline as you can. So going into the next gear, it is in the optimal rpm range.
Cone Dodger
just to add: "vtc kicks in at about 1500 rpms, and stays on until 6500 as verified in status request indicated in nissan's consult 2 factory scan tool".........then valve cuts off and retards intake cam...
1 - 7 of 7 Posts
