1 - 7 of 7 Posts
2007 Nissan Pathfinder SE, 4.0L, 2WD, 175k
Recent engine replacement due to other issues. Engine computer throws cam sensor code. Cam sensor has been replaced - no change.
Vehicle runs fine until warm with cam sensor plugged in. 20 min from cold, or 10 min if already warm. Then sputters and generally runs horribly.
Unplug the cam sensor and the vehicle takes 3-4 seconds to start but runs great. Service Engine Soon, VDC, and SLIP lights are on the dash. In addition the MPH reading on the digital part of the dash is sporadic at best and stays stuck at the last reading.
Wheel speed readings on diag machine are good.
Suspect Engine control computer ??? Any other ideas ???
Discussion Starter · #2 · (Edited)
forgot details: 2007 Nissan Pathfinder SE. 2WD. 4.0L
***Update - ran errands with vehicle today and died pulling into parking lot of second stop. Roughly 30 min after pulling out of driveway. This is consistent that it runs until warm and then dies. Won't start until cool. Then runs like a champ until warm again. Seriously frustrating!
A common problem with random engine shutdowns is a marginal camshaft position sensor or a marginal crankshaft position sensor. Most of the time when this happens, the "check engine light" never comes on; subsequently when performing an ECU code readout, there was no fault code set. There's been many members here on the forum that have had problems similar to yours and the fix was replacing those two sensors.
The best and cheapest fix for this situation is to replace both sensors at the same time; the reason for doing this is there is no way to determine which sensor is at fault with this type of condition. You can take your vehicle to a dealer/repair shop and they'll tell you there is nothing wrong after they go through with diagnostic tests because at that time the vehicle was running OK. You could end up spending $200 or much more depending on how much time/parts are used.
When replacing sensors, always use Nissan OEM parts from a Nissan dealer; aftermarket electronic items generally are not reliable, don't last long, and many times are DOA. The sensors are not very expensive; around $75.
@rogoman Thank you for the response. The camshaft sensor has been replaced (twice), but I will check the parts list for the crankshaft sensor. Thinking from what I have read that is the one on the transmission housing ??
Also considering that the ECU has a heat related fault that shows up when the engine compartment is heat soaked ??
Unfortunately a reputable used ECU seems hard to come by.
Thanks again! @rogoman
The crankshaft position sensor is located on the oil pan facing the gear teeth (cogs) of the signal plate.
Most ECUs are encased in a metal box that provides a good heat sink; so generally don't have a heat problem. However that's not the case with cam/crank sensors as they are much more susceptible to failure from engine heat.
NF Mod/Nissan Master Tech
Crank position sensor is accessible from the passenger-front wheel well. You can bend the plastic inner fenderwell liner out of the way, but it's much easier to access if you remove the liner. When an engine management issue occurs, the ECM will shut down the traction control, which causes the SLIP/VDC warning lights to come on.
1 - 7 of 7 Posts
