I have a 93 sentra 1.6 motor aproximatley 220,000 miles and havent had any troubles like this till now. I have been chasing a culprit or several and I finally need some input here. I have read alot of the posts and still cant figure it out.
Before I started to work on it it wouldnt idle to start with and then lost power, shakes upon acceleration and acts like timing is retarded bad or something. I have changed the plugs, new wires rotor button and dist cap. new air and gas filter, I cleaned the Iacv, sprayed ether to check for vaccum leaks, swapped the maf sensor and just put a new distributor in, It will idle better now but will not accelerate good or revv well and as I said before when you give it gas it shakes and doesnt accelerate good. I pulled the ecm and checked the codes and it says 55 or no malfunction. Please help out this is my main transport and I got to get it going.
Tommy
Tommy
