1 - 15 of 15 Posts
Boost anyone?
About a week ago or so, maybe, my car started making this noise like brake squeal but it does it when the car is moving. When i hit the brake, it stops. I am guessing its the brake pads. I dont want to change them and not be the problem. It might have started a longer time ago Im not sure, i drive with my system up and my windows down, i heard it when i muted it for a passing cop.
Oh, Herro!
My dad's car had a similar problem. When he drove, the front right brake would kinda squeek, but when he pushed the brakes it would go away. Turned out there was a rock jammed between the caliper and the rotor.
Boost anyone?
Thanks guys for the info, its too dark right now and i have to study. And if youre thinking what i think youre thinking, im on a study break. Tommorrow i will see what i can do. Any other suggestions??
First thing i noticed when i got my car was a squel, brakes where fine and it only happened when i turned, power steering fluid gone so i poured some in and problem was solved.
Team Serious
mine also makes a scratching sound when I am driving.....and it's real loud.... I took the wheel off 3 times to see what the problem was and i can't find anything rubbing....but my rotor is tore up and has really deep grooves in it..(rotor was resurfaced 1 month ago) any ideas?
Boost anyone?
Discussion Starter · #10 ·
I turns out i needed to change my brake pads. I had so much trouble, not putting them on but actually getting non defectious pads. The first time one pad didnt have the holes at the top which didnt allow me put those pins to hold them together . The second box looked used cause the pads were of different thickness. The third box was fine and it took me only 20 minutes to do change the pads.
1 - 15 of 15 Posts
