Friends,
I am new, hope I am posting in the correct place
I have both a 94 and a 99 Sentra that the Instrument panel light will not work when the headlights are turned on.
Additionally in the 94 the speedometer and temp guage are not working.
I have checked the fuses in the interior panel none are blown.
Are there fuses elsewhere? All help is appreciated.
Thanks,
Jim
Hi Jim. I too have a 94 sentra. the first thing you might look at is the "dimmer wheel" located (I think) to the left of the steering wheel, It might be bad, I had to replace mine.
94 arent analog i had the same problems you had with my 94 i had to replace the dimmer wheel and my water temp and speedo also doesnot work wheel speed sensor might do the trick and water temp fixed with new sensor
