Hi, I just started to have this veeeery annoying issue with my sentra, it goes on fine for a while and then starts bucking at different revs and at different speeds. It's not constant at all, it starts at lower speeds, then I go on the highway for a while, goes ok at 80-90 km/h starts bucking at 100, does it every few seconds afterwards. The thing is when I use lower speeds after that, it goes fine for a while again (few minutes). Now, the distributor cap, spark plugs, cables, air filter and air tubing were changed. I have to fix this fast, I did search the forums but there was nobody with the same issue.
Oh and it started happening after I filled the tank when it was very close to be empty.
And btw I am a :newbie: if you can please tell me what the acronyms mean when you use them that would be awesome.
Thanks in advance
John
Thanks in advance
John
