21 - 29 of 29 Posts
Discussion Starter · #21 ·
I was checking in Auto-Zone portal but not able to find any.
Checked oreillyauto and found below one but it showing doesn't fix my car 2008 nisaan maxima 3.5 SE.
Please can you provide autozone or oreilly link to buy the correct one.
Also checked advance autos and that also showing doesn;t fit in your vehicle.
Thanks,
Discussion Starter · #22 ·
Also i went to dealer to get it fixed, but it gave an estimate of 2800.
A. CUSTOMER STATES CHECK ENGINE LIGHT IS IS ON. WHEN ACCELERATING AND
IN IDLE, THE CAR SHAKES
CYL 6 IGNITION COIL DEAD. RECOMMEND ALL SPARK PLUGS AND IGNITION
COILS (1 COIL HAS FAILED BUT ALL HAVE SIMILAR LIFE EXPECTANCY)
REPLACE VALVE COVERS AND VALVE COVER GASKETS(LABOR QUOTED AS
OVERLAP WITH SPARK PLUG REPAIR, LABOR HIGHER IF DONE SEPARATELY)
COMPLETE FUEL INJECTION SERVICE.
Thinking of sell the car in this condition or should i get it fixed and then sell.
Will this make any difference ?
Thanks,
Some maximas used an NGK PLFR5A-11 plug, also known as a 6240, which is available at AdvanceAuto, Autozone, and O'Reilly. Take out one of your plugs and see what type it is.
Here's the NADA book value:
6662
Discussion Starter · #25 ·
Planning to replace coil as well for cylinder - 6 and spark plug.
Please can you suggest best Ignition coil to be use used for replacement.
As i checked the current one it says HANSHIN - AIC-3102N - 22448 - 8J11C.
Also is it ok if i replace the problematic coil and spark plug.
Any thoughts.
Yes, it's OK just to replace the problematic coil and spark plug. My preference is the Denso, Hitachi, or NGK coils from RockAuto.com.
This should be the correct coil pack. Each coil pack is independent; meaning it doesn't rely on the other coils. It only relies on the ECU to provide a "temporary ground" in the form of a pulse for it to fire.
Discussion Starter · #29 ·
Thanks Rogoman and Every one for help and Support.
I changed the coil last week and SEL sign is no more.
Thanks
21 - 29 of 29 Posts
