1 - 20 of 29 Posts
Hi Friends,
I have a maxima 2008 with 106000 miles.
I have been facing SESL pop-up last week and its still on in my car dashboard.
Also i am observing car is shaking when engine turned on in parking as well.
Also in parking when i accelerator the pedal to high speed the SESL start blinking and when i slow down the celebrator the light again pop-up instead of blinking.
Also while driving the car its bit shaking and sometime SESL start blinking and then stay on after few seconds.
I tried to read the code using car by not starting the engine and counting number of SESL LED blinks.
It seems 3060 not sure.
Please help if someone aware of this condition/Issue. Want to avoid to go dealer to get it checked and charge me alot.
Instead want to be prepare to fix the correct issue.
Thanks,
Forget about counting the number of SESL LED blinks; instead perform an ECU code readout with a portable scan tool to see if any fault codes are set. The tool can be purchased at most auto parts stores or on Amazon.com. Post the actual codes here on the forum so that we may be able to help you further. If there is one or more fault codes set, they can help point to the malfunction.
The engine shaking is most likely due to a cylinder not operating correctly but after you obtain fault codes, we'll see better what the problem may be.
The common causes for rough idle are:
  • Dirty spark plugs
  • Intake system vacuum leak
  • Dirty fuel injectors
  • EGR valve
  • Ignition coil
Hi Friends,
Thanks,
It sounds like a misfire on one or more of the cylinders. At 106,000 miles if the spark plugs have never been replaced I would start there. Over time the gap between the center electrode and the ground electrode will increase as the plug wears. This creates an increase in resistance between the 2 electrodes and a weaker or non-existent spark which eventually is insufficient to ignite the fuel and air mixture in the cylinder. Electrical current will find the path of least resistance to discharge. With the increased gap and resulting increased resistance of a worn plug, the path of least resistance is not longer between the electrodes, so the discharge occurs at a point in the ignition system other than between the 2 electrodes. It will typically first be noticed when the engine RPMs are increased or increasing (under a load) rather than when sitting idle.
Thanks for the response - Will below tool be able to detect the exact error codes to find out the problem.
Autel MaxiScan MS309 Universal OBD2 Scanner Engine Light Fault Code Reader,
Yes it will!
Yes it will!
Also if i go to Nissan dealer for re-pairs considering its a misfire Service engine light, how much it can cost "Approximate".
The going hourly labor charge these days is approximately $120/hr. If it's a difficult electrical problem, it can take several hours to fix it. For example to replace an ignition coil pack: One hour's work - $120 labor + $50 coil = $170. If the CAT is bad, the cost parts/labor will be approximately $800 - $1,000.
A misfire can be caused by any number of things such as
  • Dirty spark plugs
  • EGR valve
  • Ignition coil(s)
One way you can save money is to go to the auto part store and get the parts needed, if you know what they are. Again, if you haven't ever changed the spark plugs at 106,000 miles that is the most likely problem. A flashing SEL means there is a misfire which further supports a spark plug issue. Even the dealers are known to get their parts from local auto parts stores. The dealer will mark up the parts from what they got them for at the auto parts store and make money like that too.
Also, auto parts stores keep a code reader and will plug it into your car to read the code at no charge. They'll typically have an idea of what the code means, too.
Another issue it could be is the ignition coils. The maxima has one for each cylinder rather than a pack for all of them. These can be pricey. They'll run over $330 for all six. If only one or two is bad you can change them individually instead of all 6, but they'll run anywhere from $70-$100 each, so if you need to replace more than 2 it's probably best to change all 6.
Discussion Starter · #11 ·
Thanks for the response.
I got one tool to read the codes and observed P0306.
So it looks like Cylinder 6 Misfire.
Is this could be oil not changed as well ?
Because i have not done oil change due to Covid-19 situation in last 4 months.
Any thoughts ?
6620
Thanks,
It would have nothing to do with an oil change. It's either a spark plug or the ignition coil on that cylinder most likely.
You could swap the #6 coil with another coil and see if the misfire moves to the cylinder you swapped the coil to. For example, move the #6 coil to the # 5 cylinder and move the #5 coil to the #6 cylinder. If the misfire changes to the #5 cylinder then the coil is the issue. If the misfire stays on the #6 cylinder then it would indicate a spark plug issue.
Discussion Starter · #14 ·
Yeah thats a Good options to check, Thanks for the help.
Also Is it Ok/safe to driver with SEL on with this situation until Weekend.
As i need to do some work and will try this over weekend.
Thanks,
It'll lower your gas mileage when it's misfiring, but it'll be fine as long as you aren't driving it thousands of miles before taking care of it. I drove my 2001 maxima for with the SEL on for so long the bulb finally burned out. The SEL on mine wasn't on for a misfire though.
Thanks,
Driving the car with that misfire will be OK for a short period of time. If you let it go for several months, the misfiring will eventually poison the CAT requiring replacement.
Several things that could cause misfires:
  • Is the misfire occurring on any particular cylinder? What brand of spark plugs are you using? You should be using OEM NGK plugs; other brands such as Champion or Bosch many times cause driveability problems in Nissan engines.
  • The cam position sensor or the crank position sensor may be marginal. If you plan to replace the sensors, always use Nissan OEM parts from a Nissan dealer; aftermarket electronic items generally are not reliable, don't last long, and many times are DOA. The sensors are not very expensive; around $75.
  • Incorrect fuel pressure. Tee-in a temporary fuel pressure gauge between the fuel feed hose and the fuel rail. The reading at idle should be 51 psi.
  • There may be a major intake system vacuum leak. To check the intake system for a vacuum leak, attach a vacuum gauge to a full vacuum source. With the engine fully warmed up, the reading at idle should be 18 - 20 InHg. At 3,000 RPM, it should be 21 InHg. If readings are under 18 InHg, check the intake manifold nuts to make sure they are tight. The gasket may have failed; spray a water mist at the gasket to see if the gauge reading changes. Also check the intake plenum bellows at the throttle valve and at the MAF for cracks or loose clamps.
  • Dirty fuel injector. Run some good injection cleaner, like BG products 44K, through the system; give the cleaner about a week or two to do it's job.
Discussion Starter · #17 ·
I did try to swapped the coil #6 coil to the # 5 cylinder and move the #5 coil to the #6 cylinder.
And checked the code and observed that P0300 started showing up (Mistakenly i start the engine while code reading) .
So i reverted back everything and realized that i should have checked the code by only starting the car not engine.
Do you see will there be any difference of reading code without engine start or with engine start.
Shall i do this exercise again or what could be the next step - if i am getting P0300 after swapping the coil..
Thanks,
Probably the best thing to do at this point is to clear all the codes, then take the car for a run so that the ECU will relearn the operating conditions. After that, do a code readout without starting the engine. Alternately you can disconnect the battery for 24 hours to totally reset everything, then drive the car under various conditions; afterwords do a code readout without starting the engine.
Discussion Starter · #19 ·
I checked again today and read the code after swapping the coil #6 with coil #5 and still able to read the code P0306 cylinder 6 misfire detected.
So is this indicate the issue with Spark plug.
Also is it ok to replace only cylinder 6 spark plug only ? Also how much it can cost if going to nissan dealer.
Thanks for Quick Responses.
It's OK to only replace the #6 cylinder spark plug. The plug type is "NGK DILFR5A11 Laser Iridium" which sells for around $16 a piece. If you never replaced the spark plugs in 106,000 mi, now is a good time to replace all of them. The going hourly labor charge these days is approximately $120/hr. One hour's work to replace one plug - $120 labor + $16 = $136. Replace it yourself, it's easy.
Upon replacing the spark plug, you may find that the P0306 code still is getting set. If that's the case, it's most likely a bad fuel injector.
1 - 20 of 29 Posts
