1 - 12 of 12 Posts
In Ur Threadz - Deleting!
Matt is correct...another difference is if your car is Cali-Spec which would mean you have some extra emissions reducing items on the engine.
If I recall...that would be 1 extra o2 sensor in the front manifold and a swirl valve that is designed to create better fuel useage.
Will work for beer
high 20s basically... depending on driving, you can get anywhere from 22 to 30 on highway. most average around 26mpg.
on good days, my 3rd gen will get 31-32mpg, but on a bad day I'm in the low 20s.. on the track, I get about 6mpg.
the better fuel usage he mentioned above is bacically intended for better fuel burning, reducing in less overall hydrocarbons in the exhaust that the cat most burn up. just another pollotuion reduction measure really.
Huh?...Different motor mounts? Or do you mean different as in auto or 5spd motor mounts?
Auto motor mounts have a liquid-type filling and a sensor if I'm not mistaken.
I just changed out my front and rear MMs with poly-filled ones from a '97 and they were the same.
1 - 12 of 12 Posts
