Starts in Great Britain, Stops All Over The World
Did you know that if you buy your EBC Brake Pads and Discs as a kit instead of separately, you can save money??
A list of our Pad and Disc (Rotor) kits is shown below.
For more information, to check availability for your vehicle or to order your parts in the UK and Europe visit - www.EBCBrakesdirect.com/ebc-kits or for the USA please visit our partners Perfect Brakes Value For Money Brake Kits
PDK Kit (UK) - S1K (USA)
  • One set of Ultimax2 type approved brake pads
  • Pads are designed for a long life with minimal dust
  • One pair of OE quality replacement brake discs
Ultimax2 high quality OE replacement brake pads are manufactured in the UK and are type approved for your vehicle. Designed for long life with minimal dust and featuring Brake-In coating for faster bed-in.
One pair of premium OE quality replacement brake discs, precision cast from G3000 iron, surface ground and thermic black coated for corrosion resistance. These discs are runout tested and are an exact replacement for manufacturer discs.
This brake kit provides the perfect combination for general street use.
PD01K Kit (UK) S11K (USA)
  • One set of Greenstuff 2000 series or 6000 series type approved brake pads
  • 2000 series medium dust pads give a brake improvement of 20-25%
  • 6000 series medium dust pads give a brake improvement of 10-20%
  • Pads are manufactured in the UK and designed to last longer than OE
Greenstuff 2000 series sport upgrade brake pads are manufactured in the UK and are type approved for your vehicle. Designed for long life with medium dust and featuring Brake-In coating for faster bed-in. Greenstuff 6000 series upgrade brake pads for 4x4 vehicles are manufactured in the UK and are type approved for your vehicle. Designed for long life with medium dust and also featuring Brake-In coating for faster bed-in.
PD02K Kit (UK) - S12K (USA)
  • One set of Redstuff 3000 series type approved brake pads
  • Low dust pads which give a brake improvement of 20-25%
  • Excellent brake upgrade for street use
Redstuff 3000 series sport upgrade brake pads are manufactured in the UK and are type approved for your vehicle. Designed for long life with low dust and featuring Brake-In coating for faster bed-in.
PD03K Kit (UK) - S13K (USA)
  • One set of Yellowstuff 4000 series type approved brake pads for street, trackday or drift use
  • Designed for use on faster, higher horsepower vehicles and for short track use
Yellowstuff 4000 series sport upgrade brake pads are manufactured in the UK and are type approved for your vehicle. Designed for faster and higher horsepower vehicles and for short track use but due to heat range, these pads are great as a brake upgrade on 4x4 vehicles particularly when towing or under heavy load. Featuring Brake-In coating for faster bed-in.
PD06K Kit (UK) - S2K (USA)
  • One pair of slotted upgrade brake discs with grooves that are designed to dispel gasses and debris
Greenstuff 2000 series sport upgrade brake pads are manufactured in the UK and are type approved for your vehicle. Designed for long life with medium dust and featuring Brake-In coating for faster bed-in. Greenstuff 6000 series upgrade brake pads for 4x4 vehicles are manufactured in the UK and are type approved for your vehicle. Designed for long life with medium dust and featuring Brake-In coating for faster bed-in.
One pair of slotted upgrade brake discs, slots dispel gasses and debris and give quiet braking. Manufactured from unique disc alloys and thermic black coated for corrosion resistance. These discs are runout tested.
PD07K Kit (UK) - S4K (USA)
  • Front and full vehicle kits contain FREE 250ml bottle of BF004 brake fluid
PD08K Kit (UK) - S9K (USA)
PD12K Kit (UK) - Not available in the USA
  • One pair of slotted and dimpled upgrade brake discs with grooves that are designed to dispel gasses and debris
One pair of slotted and dimpled upgrade brake discs. Wide slots and blind drilled dimples are designed to dispel gasses and debris. Manufactured from unique disc alloys and thermic black coated for corrosion resistance. These discs are runout tested.
PD13K Kit (UK) - S5K (USA)
PD16K Kit (UK) - Not available in USA
  • One pair of blade upgrade brake discs with bi-directional slots that are designed to dispel gasses and debris and give silent braking and better pad venting
One pair of slotted upgrade brake discs, precision cast from G3000 iron. Bi-directional slots are designed to give silent braking and better pad venting. Thermic black coated for corrosion resistance. These discs are runout tested and are an exact replacement for manufacturer discs.
PD17K Kit (UK) - Not available in USA
PD18K Kit (UK) - Not available in USA
PD40K Kit - Full Vehicle Set (UK) - S20K (USA)
  • TWO sets of Ultimax2 type approved brake pads
  • TWO pairs of OE quality replacement brake discs
Two pairs of premium OE quality replacement brake discs, precision cast from G3000 iron, surface ground and thermic black coated for corrosion resistance. These discs are runout tested and are an exact replacement for manufacturer discs.
