OK SHEs in shes beautiful but she won't start on her own! We finally got the S13 DET in the S14 completely.. bumpers back on with the intercooler mounted etc etc etc. We can get it to run if we use a little bit of ether on start up. She will run and hold idle at about 1500. THe only problem is when we step on the gas the rpms go up and then come down to the point that the car is going die! Plus the car won't run over 4500 RPM.. Which we think we might have solved with the MAF wire. We haven't gotten a chance to try it out! Just so you know the fuel pressure we cannot check without a guage but when you pinch the hose upon start up there is plenty of pressure. There is spark, the injectors are ticking away, new plugs, running out of ideas... Battery turns over just fine along with the starter! HELP HELP
We found out that it was the MAF wire we extended... DOn't ever extend the MAF wire while the ECU is hooked up! :) DUMASS! Now the Ecu is fried.... and it won't rev past 2500 because the ecu is cutting fuel. so we eliminated that problem!
