Hey everyone I need some help.. My car runs terrible when it is cold what so ever. When I first start my car up in the morning I can't even rev the engine, it just cuts out and has really bad throttle lag. Once the car is fully warmed up I can somewhat drive it but it cuts out really bad when I get over about 2500 rpms and black smoke comes out of the exhaust so it is running rich. Now if it is a hot day out, and my motor is warmed up.. it runs like a dream and doesn't cut out what so ever. My temperature sensor on my gauge cluster is maxed out at hot when the motor gets warmed up, I don't know why.. I put a ka temp sensor in place of my sr sensor to see if that would fix it and it still reads HOT! One thing I took note of, when I went to changed temp sensors, no fluid came out when I removed my sr sensor, it was dry inside. And no my motor is cooling fine, I have dual flex fans with an electronically activated by temperature, and my coolant level is fine.
**65 degrees or higher outside, my car runs PERFECT once warmed up. Anything below that, it will cutout no matter what***
So I have a feeling that my car running rich like this and cutting out has to do something with either my gauge temp sensor, or my ecu sensor. But I don't know how to test this or what to look for. Help please ? I'd really appreciate it guys.
