I have a '93 S13 HB with automatic transmission, and it shifts into 1st and 2nd just fine, but once it tries 3rd, it revs high like its in neutral and barely picks up any speed. I tried different solutions from other forums and threads but nothing worked so far. It automatically shifts up to second, and I can manually shift into second after it messes up. Any feedback or things to try helps.
Check the ATF level to insure it's at the full mark. If the ATF is dark brown and has a burnt smell to it, then there is most likely internal damage. Also check the TPS sensor for proper operation.
