Recently i had the oil changed on my maxima. They put a 5w-30 instead of a 10w-30 and my car started runninig hot. the ? that I have is, could my cars heater and air still be working if the thermostat or water pump was going out.
overfilling won't cause it to run hot...
the only thing I know of they could have possibly done is to hit some vacuum hoses while changing the oil filter... disconnecting a few vacuum hoses to the EGR or something can make it run hot...
I don't think the issue is related to the oil change though..
Yeah, it's not the oil, make sure you have coolant/no leaks, and then look under the hood for something loose or dissconnected that the lube guys might have disturbed. (the term lube guys is disturbing, but u get the idea)
Nissan Forums is the go to place to talk about your favorite Nissan model, including the Rogue, Maxima, Altima and even sports cars like the 370Z and 200SX.
