1996 Canadian B13 5spd
Whenever I'd start the car the rpms would drop low for a moment, sometimes stalling. It would go start-down-up-down-idle. I could also feel the car shudder a bit when I let off the gas and came to a stop in neutral. So I took it in for a tune up and it improved but i still get the occasional momentary low rpm at startup and occasional irregular rpm when coasting to a stop. Is this normal? I don't remember my other Sentra doing this.
you may want ot take a look at the idle speed actuator. it may be clogged with carbon. you might be able to clean it, if not it will have to be replaced. I have a friend with a turbo GA and he has the same problem. the idle is erratic and the car surges sometimes at low rpm
