I realize this is OLD, but I'm SO confused. I bought a 2002 sentra se-r over a year ago. It has an alpine 250 watt v12 amp with a 10 inch car sub(can't remember the brand) in a home theater sub box. A pioneer mvh-x36bt head unit. The previous owner replaced the rear deck speakers, they are 6.5's(see no tweeters in the rear deck or a spot for them). They also disconnected the pillar tweeters and replaced the front door speakers(also 6.5's) and installed tweeters in the door panels up high(no crossover by the way). Under the pioneer head unit is the heat/blower control panel, then below that is a rectangle space that looks like it could have had the chance changer in it. Now its just a plate covering the hole. The bottom side of the rear deck has a white plastic square box the size of a butter dish. I see no spot where a sub could have been mounted. Does this sound like my car had the fosgate system in it? It sounds like i have/had some parts of the fosgate package and some aren't there. I'm very confused.We got screwed
I got this off of the associated press website and from what i can read looks like all hte components of the rockford system was advertised with all the components of the sytem being rockford and not clarion check this out.
Rockford Fosgate Partners with Nissan North America
Rockford Fosgate announced that it has reached an agreement with Nissan North America to develop audio systems for three new Nissan vehicles for model year 2002, which all go on-sale in the summer of 2001.
The system, Rockford Fosgate's first ever as a direct supplier to an original equipment manufacturer (OEM), will be featured in Nissan's popular Xterra sport utility vehicle, the new Frontier truck, and the soon-to-be-announced Sentra SE-R sports sedan. Rockford Fosgate's OEM systems are designed and manufactured specific to each vehicle model and include AM/FM/CD radio source units, subwoofers, speakers and amplifiers.
"Rockford Fosgate customers live high performance lifestyles," explains H. Christopher Parvin, Rockford Fosgate's director of marketing. "They expect it from the vehicles they choose and they demand it from their music. Rockford Fosgate satisfies the music, and these Nissan models satisfy the high-octane lifestyle."
This partnership and the addition of the high-end Rockford Fosgate mobile audio product into these vehicles allows Rockford Fosgate to create brand awareness of the Rockford Fosgate name in the OEM market, enter a new distribution channel, and gain new customers.
"Rockford Fosgate is a premier aftermarket mobile audio systems manufacturer, and they are coming onboard with Nissan so we can offer our customers the best," says Scott Fessenden, Nissan North America's director of marketing. "Rockford Fosgate desires to align itself with an innovative, youthful and confident automotive manufacturer. Nissan desires to carry an audio system known for high quality and power, as well as an edge in its attitude. This represents a strong marriage of goals and vision. We look forward to a long and successful relationship with Rockford Fosgate."
To optimize performance, the high-efficiency amplifiers feature independent equalization curves for each channel. The tentative product specifications for each model are as follows:
The 2002 Nissan Xterra SE & XE will include: system designed to Rockford Fosgate's sonic signature "The Punch"; a two DIN AM/FM/RDS/6-disc source unit/in-dash CD changer (frequency response (CD) +\- 3dB, 20Hz-20kHz); an amplifier that drives 1-ohm loads per channel and 72 watts (12V Batt) per channel with built-in equalization, custom tailored to the vehicle; the lower front door speaker uses a 6.5" 1 ohm driver and a special 1 ohm voice coil; the upper front door speaker uses a 4-ohm, 25mm tweeter; the rear speaker systems are 2-ohm 6" x 9" full-range speakers located in the rearmost side panels.
The 2002 Nissan Sentra SE-R will include: system designed to Rockford Fosgate's sonic signature "The Punch"; a single DIN AM/FM/CD source unit (frequency response (CD) +\- 3dB, 20Hz-20kHz); an amplifier that drives 1-ohm loads per channel and 72 watts (12V Batt) per channel with built-in equalization, custom tailored to the vehicle; the lower front door speaker uses a 6.5" 1 ohm driver and a special 1 ohm voice coil; the upper front door speaker uses a 4-ohm, 25mm tweeter; the rear speaker systems are 6.5" coaxial speakers using a 3-ohm coil for the mid and a 4-ohm tweeter; the subwoofer is a single 8", dual 2-ohm voice coil in a custom enclosure.
The 2002 Nissan Frontier Crew Cab & Supercharged Frontier will include: system designed to Rockford Fosgate's sonic signature "The Punch"; two DIN AM/FM/RDS/6-disc source unit/in-dash CD changer. (frequency response (CD) +\- 3dB, 20Hz-20kHz); an amplifier that drives 1-ohm loads per channel and 72 watts (12V Batt) per channel with built-in equalization, custom tailored to the vehicle; the lower front door speaker uses a 6.5" 1 ohm driver and a special 1 ohm voice coil; the upper front door speaker uses a 4-ohm, 25mm tweeter; the rear speaker systems are 2-ohm 5" coaxial speakers located in the rearmost side panels; the subwoofer is a single 8", dual 2-ohm voice coil in a custom enclosure.
Specifications for all models subject to change without notice.
Link for more info: www.rockfordfosgate.com
