1 - 9 of 9 Posts
I am a dumbass since I started my car without connecting the throttle body (after installing my CAI). It set a code. I figured, no biggie, disconnect the battery and it will go away. Well, it hasn't. Anyone know how to reset the codes? I better not have to run to a damn dealer!!
thanks
Man, the code is still there. Could it be the MAP sensor maybe? I am all out of ideas. I heard AutoZone will read codes for free, maybe they can clear it too.
· in^3,N20,RPM,PSI
Well on the b14's you take the ecu out of the mount, turn the key to the position right before it turns the starter and you rotate the screw to the most clockwise position (it only turns one way I don't remember) and hold for 2 secs and then turn it back, after the light flashes you the code you do it again to reset the ecu (really reset). Anyone got any info for the b15?
Just to update you guys:
I don't think it has anything to do with time. I believe it has to be either miles or number of times you start your engine. Mine went out today finally!
1 - 9 of 9 Posts
