Using a OBD reader, it showed P0306/ which is the 6th Valve for a Nissan Murano SL 2005.
After replacing the Ignition coil and Spark plug for the 6th Valve, I still can't figure out how to removed the check engine lights on my dash.
When i use the code reader, it shows NO issue or trouble, but light is still on.
Sup Mod keeping the peace
Does your OBD scanner have the capability to clear all codes; if it does, just try to clear all codes several times. If your scanner does not have that capability, then you'll need to use a more advanced scanner.
I think if you fixed the issue after a few cycles the engine light should go off. Otherwise, I think there is a manual method to get and clear codes that you should be able to look up. At least there is for my 2006 X trail.
