Just finished replacing head gasket on '95 240SX SE and she fired-up on first attempt, but now won't start again! It was a "shaky" idle, so I tried to get out and adjust the timing by turning the distributor, but it stalled before I got to it. I tried putting the distributor in proximity to where it was initially (both retard and advancing), but hasn't fired-up again...
I checked CEL codes on the ECM, but only get "55", which I believe is "no codes". I have replaced the cap, rotor, plugs and O2 sensor, but the initial start-up was with the old ones (I was going to replace them anyway).
Since it DID start, I don't think anything is disconnected, but have double-checked and have found nothing not plugged in (either wiring or vacuum)
Do scanners tell you more than the CEL (Check Engine Light)? If so, does anyone rent/loan these scanners...this is a friend's car (which is probably going to be sold), so don't want to invest too much if don't need to.
Any ideas are greatly appreciated.
Thanks!
Thanks!
