After some snags like a tranny mount bolt snapping while the mount coming off the tranny was still in it and not having 100% of all the bolts, ive caught another snag. The transmission is resting where it should be and has the one mount in on the driver side frame. 3 bolts are holding it to the engine.. The two at the top and the one closest to the rad. This is where I need your help:
This is a drawing of the transmission if you were to look at it from the drivers side. The black dots represents the bolt holes. The black holes circled in red represent the bolts that are in place right now meaning I have used the right bolts. The blue circle is the one im having most problems with.. It's the starter bolt. I have about 4 bolts lying around and Ive tried each bolt about 10 times which leads me to believe I probably lost the right size bolt... If anyone has the time, could they tell me what size those other 3 bolts are?
Example: Bottom 2 bolts are the same size in legnth. They are 4" long with the threads only being 1 inch off the bolt. Also, the thread size is fine
That was just an example.. I think that the 2 bottom bolts are the same size in legnth though...
I know this is a long shot but Im just hoping someone took the time to remember the bolt sizes.. I did but I knocked them all over the place =(
