check the trunk to see if the harness is visable...if it is, the bulb should twist and come out. If not you'll have to pull it apart from the inside of the vehicle.
Nissan Technician
Grab the 3rd brakelight assembly, push it towards the glass and then while wiggling assembly, lift upwards. Should come off...good luck!
