Has anyone replaced the radiator clutch fan with an electric fan? If so any recommendations on which fan and thermostatic fan control? I already plan to get a beefier altenator. Just looking for ideas and suggestions.
NF Mod/Nissan Master Tech
Personally, I wouldn't replace the mechanical fan clutch. They work well and are reliable and you don't have to worry about an electrical part failing and causing an overheat. If you want to add more cooler, consider adding a pusher fan to the front of the radiator or A/C condenser (if you have A/C) core as an auxiliary cooling fan.
