very simple... my cable was pretty loose so it might have been eeasier for me. in any case... first, you might want to loosen the clutch cable adjusting nut right under and a little left of the battery (from the front). i didn't need to. then just slide that end out from the arm that links to the transmission. it's just looped on, no tools needed. follow the cable up towards the steering column area and you'll see two bolts on on a diamond shaped thing-a-ma jigga. loosen that and slightly remove it away so it hangs out. also, by removing it a little, it shines some light into the footwell area where the last endo f the cable is hooked on. easier to see. at the clutch pedal, the other end of the cable is also hooked way up in there. just need a flash light. it should already be unhooked if the tension is released. then, just pull it out from the front of the car, and that's it. you could do it the other way too. start from the inside. just depends on how loose the cable is to begin with. should take 20 minz. good luck
Peace
CMo
