1 - 8 of 8 Posts
Nissan Technician
1st off, no typing in caps...we think you are yelling at us!
To answer your question, you'll need to remove the wheel well plastic liner to access the antenna assembly.
There are 2 spots where the antenna detaches the top and the bottom. Youll have to unscrew the top with needle nose pliers. And the bottom the antenna is bolted to a bracket I believe its 10mm.
1 - 8 of 8 Posts
